Changing headlights on 07 LR3 SE
Old Jul 10, 2024 | 11:54 AM
zlasker's Avatar
Default Changing headlights on 07 LR3 SE
I bought a used 07 SE with 124K on clock. I would like to change out the old (static?) headlights for the self-leveling lights that come on the HSEs. Does anyone know if this is a plug n play install, or are the connections not there on the SE for steering and suspension input needed to inform the movement for the self-leveing lights?
Old Jul 10, 2024 | 03:03 PM
kajtzu's Avatar
You can upgrade from Halogen to Xenon plug and play (and changing CCF if you don’t want lights to flicker at start).
You cannot upgrade plug and play from Halogen or Xenon to Xenon-AFS, that will require AFS ECU.
Old Jul 10, 2024 | 03:16 PM
zlasker's Avatar
Thank you for the quick reply. So to be clear I cannot install the headlight in the link below without adding some additional electronics?
link to part:
https://oemusedautoparts1.com/produc...4aAkpdEALw_wcB
Old Jul 10, 2024 | 03:28 PM
kajtzu's Avatar
No, that one should be fine (HID = xenon) and you can replace your halogens with those. 👍
The ones you cannot upgrade to directly is HID AFS. AFS means the lights can swivel left and right when you turn the wheel at certain speeds.
Old Jul 10, 2024 | 03:33 PM
kajtzu's Avatar
This one will not work for you.
Old Jul 10, 2024 | 03:55 PM
zlasker's Avatar
Got it - thanks so much!
Old Aug 16, 2024 | 01:49 PM
zlasker's Avatar
Follow up question --- I bought used HIDs off ebay to replace my HALs and installed. The headlights come fine on but the turn signals on the new front light assemblys dont work, just a fast blinking. Thought it was a bad bulb but changed them and still same issue. I then noticed that the wires on the plugs on the car (LR3 07 SE) are 7 wires, whereas the HIDs had a cutoff old plug included that showed 8 wires. Is the wiring the issue or perhaps I need to reprogram the car with the an IID device to Xenon? (IID device coming today haven done yet). Or do I need to splice some wires? Pics attached, any help most appreciated.
Original lights on car
ebay purchase
This wiring harness came with HIDs from ebay
This is OEM wiring on car
Old Aug 16, 2024 | 04:01 PM
kajtzu's Avatar
Huh. In Europe it’s plug and play. I glanced at the wiring diagrams (you can download yours here: http://rave.stringsandints.com/LRL18...R3-Wiring).pdf) and it didn’t seem like turn signals would have something special for NAS.
Just to verify, you used W5W bulbs, not LED, right? I ask as fast blinking tends to mean that the vehicle thinks there is a fault with the lights.
Old Aug 16, 2024 | 08:06 PM
zlasker's Avatar
I used the turn signal bulbs from the old light assembly, which probably wasnt the best way to test. I will get the proper bulbs from Atl Brit and test again. Will also have IID tool soon so can change to Xenon in settings. Thanks for your help --- Im going to figure this out! i am inordinately fond of the look of the HID lenses...
Old Aug 17, 2024 | 01:41 AM
kajtzu's Avatar
Sorry, I was thinking about the positioning lights, they’re W5W and many swap them to LED because they “look cooler”.
The front turn signals are 3157 type bulbs.
