Cheapo LR3 build
Old May 21, 2016 | 04:38 PM
bbyer's Avatar
Default link to HVAC files
Originally Posted by cmb6s
On a side note, I'm still having A/C issues as well. When it gets hot, my A/C just randomly decides to stop working for a while, then it starts up again. I've checked my pressures and both low and high appear to be good for the operating temperatures that day, so I think my system is charged. I actually think I overcharged it, so let some out until the pressures came down to where I liked them. Is the resistor that you're talking about, the same as the final stage resistor in the range rovers? In other words, it just controls fan operation... it wouldn't have any influence on the A/C, would it?
I am not really answering your question, but the link below contains a number of files, pdf's, diagrams etc on the heater AC system. You might find some sort of an answer there.
DISCO3.CO.UK Photo Gallery - Heater Air Conditioner System
Old May 22, 2016 | 10:43 AM
MrWesson's Avatar
Added 31.5" Cooper AT's and IIDTool lift.
Yesterday I was preparing a poser shot(not the one in the picture) on a rock(found the only one in FL) and damaged my front rocker/fender. Got the tire on the rock and felt the tip going the other way.. I was safe from a rollover but it sure felt like it was going.. Panicked and crunched it.
Ouch.
Was worth it though.. Great time!
I was shopping for a replacement when I decided to just use a heat gun to reshape it and the door rocker.. Came out nice enough until I bash it again I may install rock sliders even though I live in FL because I actually use my LR3 pretty hard.
Old May 22, 2016 | 03:16 PM
houm_wa's Avatar
That came out great!!! I can't even tell.
I hit a rock (because my wife refused to get out and spot me) once with my front bumper right in the corner on the passenger side...put a golf-ball sized dimple in the bumper-cover. It was unsightly and I was pissed.
After trying and failing to push it out and body shops quoting me cost-prohibitive estimates, I did some research, got out a hair dryer and fixed that $hit myself! I was real happy and it looked perfect.
Old May 22, 2016 | 05:47 PM
bbyer's Avatar
Default Your wife's fault, I gather?
I am led to believe then that the dent was your wife's fault and that is why you were annoyed.
That would not play around my place too well so if you got supper that night, you did well.
Old May 22, 2016 | 07:23 PM
houm_wa's Avatar
I have come to believe, like Jimmy Buffet, that "it's my own damn fault."
Old May 23, 2016 | 09:01 PM
Zelatore's Avatar
FWIW I think sliders are the first mod most should do, at least after tires and a bit of lift. There is precious little break over available on these trucks, and a good set of sliders will serve as skids as well as they'll run all the way inboard to the frame rails.
Old May 24, 2016 | 09:32 AM
djkronik57's Avatar
Is there a recommendation on the best sliders? Been looking around and it seems like there are a couple different options from $600-1200. Some seem to have drawbacks (like vibrating or amplifying road noise) and some are steel and others aluminum.
Old May 24, 2016 | 09:53 AM
DavC's Avatar
most of the northern california club guys have Tactical Rovers sliders
Old May 24, 2016 | 10:51 AM
houm_wa's Avatar
Don, I agree that sliders need to be high on the list. They don't all go far enough inboard to cover the frame rails, however. The Tactical Rover sliders do, I believe...as do the Rover Specialties sliders; the latter I believe are no longer made.
DJ you are probably going to have to just look around on-line. Lucky8 is probably your best source.
Old May 24, 2016 | 05:08 PM
Zelatore's Avatar
I'm a fan of the Tactical and yes that's what I'm running. They offer maximum protection and even offer a bit of a step to help getting in/out of the truck when it's lifted (this can help sell the wife in some instances ) Drawbacks? They do make the compressor louder, and if you've been playing in the mud you won't be able to stand anywhere near the truck without getting your pants dirty.
OffroadFrance
Aug 13, 2015 10:17 AM
Savannah Buzz
Jul 28, 2015 08:50 AM
Scope
Jan 18, 2015 12:37 PM
William48151623
Engine Swaps
Sep 28, 2014 05:45 PM
s10lowrider1994
Sep 28, 2011 04:32 PM
