"Check Spare Tyre Pressure"
Old Dec 20, 2016 | 12:15 PM
djkronik57's Avatar
Default "Check Spare Tyre Pressure"
This message popped up on start up recently. I have the full sized spare and from what I can see, there is no way to actually check the tire pressure without lowering it down. No clever tricks for this?
Old Dec 21, 2016 | 03:13 PM
DavC's Avatar
Sounds like you have to lower it down and check it. GAP tool can turn off all TPMS warnings however.
Old Dec 22, 2016 | 03:36 PM
djkronik57's Avatar
Neither option sounds ideal, but don't have an IID tool yet so guess I have to lower it down. Hopefully the manual does a good job of explaining the process, and I guess it is good practice and good to make sure everything is in working order in case I need it.
Old Dec 22, 2016 | 07:24 PM
EastCoast's Avatar
super simple... there is a rubber plug on the floor of the rear hatch area that hides a "nut" that you turn to lower and raise the cable attached to the rim. Always a good idea to do it occasionally and to lube it lightly for when you really need it and it's -30.
Old Dec 22, 2016 | 09:04 PM
Jagfixer's Avatar
I use a truck (dually) gauge and air tap. Don't have to lower, just raise suspension and check. The dually gauge is longer and has 2 angle head to pull gauge to measure. My tap is same for filling.
Rufflyer
Jan 21, 2024 03:56 PM
Richard Moss
Jun 2, 2014 12:59 AM
megathunder
May 5, 2014 09:18 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
gsgtsg
Aug 1, 2008 11:31 AM
