Coilover conversion question
Hey now,
I'm new to owning Land Rover's and picked up a 06LR3 at auction for cheap because it had hit a curb. Fixed the immediate damage and aligned it perfectly but it has a blown shock on that corner- the problem is that someone already did the coil-over conversion on this rig and I'm not sure what to buy in order to replace that shock. is it just the standard shock that is available on rock auto for non air LR3's or do they do something special with the kits?
Thanks for the help guys. I tried to search it out but my google-fu is not very good.
Zach
Zach
Hey now,
Zach
Zach
You hate to assume but it's most likely stock height and not the 2" lift conversion
If you have suspension errors showing on a coil converted LR3 and there's no bypass mod box by the suspension control module, then there's really no telling what they put on the truck. Likely the cheapest they could find tbh. If there is no stamp/sticker or something else to id the shocks/coils, you'll probly just have replace components on both sides and see how it goes. In this case, yeah, I'd go with a half decent brand on Rockauto or wherever.
