Compressor problem?
Old Jul 17, 2025 | 08:10 AM
Tonyallam's Avatar
Default Compressor problem?
  • The suspension has just started to go down on the rear drivers side after a few hours.
  • Water drips out of the compressor box when you are parked and it raises slowly could the desecant be dead?
  • Couldn't find any air leakage on corner that goes down
Are the 2 related or just two separate issues
Old Jul 17, 2025 | 02:42 PM
houm_wa's Avatar
Hard to say. I'd probably start by getting eyeballs on the compressor. You can remove the cap and look at the desiccant; replace if it's toast.
Old Jul 17, 2025 | 06:02 PM
DakotaTravler's Avatar
Do you have rear climate control that you have been using lately? It drains near that area. Really no way water could leak out of the compressor.
Old Jul 17, 2025 | 06:56 PM
loanrangie's Avatar
Get a spray bottle with soapy water and check the front and central valve blocks for leaks, unless you get a dash message saying raising slowly or problem filling reservoir its unlikely to be a compressor fault.
Old Jul 17, 2025 | 09:41 PM
Tonyallam's Avatar
I use the rear Aircon, it's extremely humid and very hot at the moment so that might be it though no drips at the front.
Soapy water on the valves then to check for air leaks.
Old Jul 17, 2025 | 09:43 PM
Less drips up front because, by design, the water drops on the exhaust. So it can be a little hit or miss with puddles up front. That or your drain ports are clogged! I had the that happen and ended up with dam carpet. They are very easy to clean.
Ericlockheed
Dec 19, 2022 08:58 AM
Avs2021
Jul 2, 2021 12:11 PM
sayvillerx
May 7, 2021 06:40 AM
05TurboS2K
Aug 7, 2019 07:47 PM
GCS1
Feb 17, 2008 07:30 PM
