Coolant capacity
Old Feb 2, 2022 | 03:52 AM
Altitudes's Avatar
Default Coolant capacity
Hello.
Pls advise how many liters of coolant a disco3, year 2005 takes. I plan to flush it and i need to budget accordingly. I will factor in the mixing ration to determine how many liters to buy before mixing to fill the reservoir.
Old Feb 2, 2022 | 12:06 PM
douglastic's Avatar
DexCool (OAT, orange stuff)
15L dry fill, 9.5L refill
I have rear AC, not sure if that affects capacity
Old Feb 3, 2022 | 10:38 AM
kajtzu's Avatar
It does affect the volume of the cooling system. Vehicle with rear heater should have a capacity of 12 liters and 9.3 liters for a vehicle without…… according to the workshop manual, I mean, for the D3 V8. I assume it’s not “dry fill” but that the engine block has several liters (15 - 9.5 = 5.5) inside it at all times.
The only reliable way, I guess, would to use a vacuum tool to suck absolutely everything out, then fill to proper level on side of expansion tank, etc.
Old Feb 3, 2022 | 11:12 AM
douglastic's Avatar
So . . . just buy 2gal of coolant, 2gal of distilled water, flush, then fill til its full. Leftovers for eventual topping up.
Bleeding properly is the real fun!
Old Feb 3, 2022 | 02:00 PM
kajtzu's Avatar
Tell me about it…. 😂😂😂
Old Feb 3, 2022 | 04:43 PM
Blackngold77's Avatar
Amen.
All but guaranteed to have some air in there no matter how much bleeding. Plan on stopping 5 min into the 1st drive and burping it
Old Feb 4, 2022 | 06:56 AM
Altitudes's Avatar
Default Coolant
Thanks to you all.
Its actually an HSE TDV6.
And for you to appreciate, let me add that i want to flush the coolant because i think i have been using low quality coolant for about 3yrs. I recently started topping uo like 250mls every 2-3 weeks which was never the case before. So, i think its the coolant evaporating because the mechanic says he can not see any leakage.
Old Feb 4, 2022 | 11:34 AM
douglastic's Avatar
my radiator was weeping/crusting at the seam between end caps and body - no drips or puddles, very hard to notice.
Old Feb 4, 2022 | 01:35 PM
tracyc's Avatar
In a properly sealed system, coolant can't evaporate out (unless you overheat and it vents out as steam). There has to be a leak or a head gasket issue if you're having to add to it that often. I'd do a rigorous visual inspection and a head gasket test.
Originally Posted by Altitudes
Thanks to you all.
chad420
Oct 26, 2009 09:38 AM
Gavster
May 13, 2009 08:43 PM
cruzin
Nov 14, 2008 07:30 PM
bigugly82
Aug 23, 2007 04:32 PM
bigugly82
Aug 22, 2007 08:04 AM
