Coolant leak
Old Mar 11, 2020 | 02:11 AM
Pedro Campos's Avatar
Default Coolant leak
Hey thanks ahead of time. I have 2006 LR3 . Love it but getting over it due to this coolant leak that I have been trying to fix for several months now.
1st- Initially when I noticed the leak I traced it to the water pump. I replaced the water pump. 2nd- Then I went back and noticed the thermostat housing leaking. So I replaced the thermostat housing. 3rd- I noticed the leak still coming from the area of the water pump and or the bottom (top of housing was clean) of the thermostat housing. 4th I decided maybe the gaskets on the water pump are no good. So I decided to replace the gasket that goes in the water pump as well as the gasket that goes from pump to engine block, both with paper gaskets.
​​​​​​Unfortunately it is still leaking. On the last go while I was replacing the gaskets I also made sure to tighten it down a bit more than usual. This car is still leaking from the same area and I am at a loss 😣 does anyone have any ideas? Thanks again!!!
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
