Couple things for the brain trust....
Old Mar 24, 2022 | 11:01 PM
houm_wa's Avatar
Wouldn't that set a more permanent fault, icon or have physical symptoms? There wasn't even a fault stored.
Old Mar 24, 2022 | 11:36 PM
Blackngold77's Avatar
Wonder if the shifter itself is dying, or if a little bit of something got spilled on it and made a momentary short.
Old Mar 25, 2022 | 02:03 AM
DakotaTravler's Avatar
It did not store a code for me when I had the issue. Not sure why.
Old Mar 25, 2022 | 02:28 PM
houm_wa's Avatar
Maybe it just didn't "sit' right in Reverse that time? It sure doesn't happen on the regular....or maybe ever before. There is no way anything spilled on it. I don't eat or drink in that vehicle.
Old Apr 25, 2022 | 02:50 PM
houm_wa's Avatar
Your error reminds me of what happens with the shift selector does not agree with the transmission. Meaning the shifter linkage is maybe binding up or its slightly misaligned, come out of alignment.
Dakota, is this something that lubricating the linkage (as you've mentioned in other threads) could help with?
Old Apr 25, 2022 | 06:42 PM
Yup. Fixed my issue, I did not even install the shift linkage kit I bought because lubrication fixed it. I lube it once a year or about now with silicone spray.
Old Apr 25, 2022 | 07:25 PM
houm_wa's Avatar
Thanks....I might just replace the whole thing; it's cheap kit.
My 2005 pops out of 1 when using Command Shift. I downshift from 2 to 1, and it pops back into 2. It did that ever since the CA Stop issue was fixed. I always figured it was a by-product of the new algorithm.
My 2006 will sometimes just not go into 1 from 2.It just stays in 2.
I'm hoping that new linkages on both LR3s will remedy this, too!
Old Sep 20, 2022 | 06:31 PM
SeattleDriver's Avatar
Where in the linkage do you lubricate?
Houm_wa any updates on yours? I seem to be experiencing a similar problem, same fault message, but I’m getting communication codes and shift lockout.
Old Sep 20, 2022 | 06:32 PM
At the visible linkage at the trans. For US models, that would be passenger side of trans towards the middle/front area. Heat shield may block view a bit.
Old Sep 20, 2022 | 08:43 PM
houm_wa's Avatar
I had mine replaced and it didn't make a difference in the behavior I was experiencing, so it must have been something else. Oh well, the parts were so cheap I figured it was worth a shot.
russlowe
Mar 24, 2022 11:30 PM
WALLACEJ
Mar 30, 2021 05:01 PM
Philip Chan
Jan 31, 2020 06:24 PM
hshamamian
LR4
Jan 20, 2020 03:30 PM
ceven18
Feb 28, 2008 09:55 PM
