either way, the most we have is 2 holes for USB or cig lighter.
you can buy rocker switch dual USB fixtures.
if you interested, email me. We can work it out.
No worries as you know I have switch mounting all squared away. Need to get off my butt and just swap outlets out and wire in a few extra USB charge points
As a quick follow on; The OP wants to remove the printed symbol on the covers. I think the first two comments covered the best ways for that, but I say use the space more wisely, As a metaphor; don't just paint over the front of an unused building, Remodel it and make it useful for the community as a whole and in your case less offensive as well.
That said, here is a picture of the neighborhood with a few additions/improvements.
Here is the wiring side during the install. I used a 12 pin connector because I had it, All of the switched trigger a relay so it is all low current. I suppose grouping the grounds together could eliminate a few wires, but like I said I had it, so I used it. and all of the other items in the console had a connector so...............
