Despite my best efforts: suspension light won't go away
Old Sep 12, 2022 | 07:48 AM
SeattleDriver's Avatar
I looked at my manual and could only find that the supply voltage to that sensor is 5.0V
Old Sep 12, 2022 | 07:52 PM
Rufflyer's Avatar
Well that sort of makes sense. 4.9 for 14 psi and maybe .1 for 240 ish.
Either way I cleaned out the reservoir valve block and put in new O rings, but unfortunately I have driven it much I am not sure if the light will stay out or not. I will report back at the end of the week and let you know if it solved the issue.
Old Sep 15, 2022 | 06:20 AM
Rufflyer's Avatar
New O-Rings did not solve the problem.
When I removed the valve block there was still pressure in the reservoir so I think that line is OK. I am going to pull the line from the compressor to the valve block and see if it is restricted. I still suspect the sensor may be bad. Cost of a sensor is 3/4 the cost of the valve block so I think I will capture some more live data before I go that route.
After that, I guess it is tearing into the AKM compressor.
Old Nov 17, 2025 | 05:48 AM
cavenger123's Avatar
just curious if you were able to figure out your problem. I know this was a long time ago. I am getting this error after installing a cheap valve block:C1A18-64 (AF) Pressure increases too rapid when filling reservoir - Algorithm based failure - signal plausibility failure
At 214209 mi
Triggered on 15-11-2025 16:23:23
Old Nov 18, 2025 | 10:02 AM
Rufflyer's Avatar
Default Sorry for not giving a follow up post.
At 214209 mi
Sensor in distribution valve was bad. I replaced the whole valve block and it worked fine after that.
Old Nov 18, 2025 | 12:23 PM
good to know! What valve block did you buy and how much did you pay?
Old Nov 19, 2025 | 06:58 AM
Rufflyer's Avatar
I don't recall exactly which one or from who, but I tend to buy OEM or LR parts when it comes to the air suspension. Most likely an OEM option.
Jeff
Old Nov 21, 2025 | 07:55 PM
Gnomadf's Avatar
At 214209 mi
I have this same code and an amber light but only when it's cold outside, and I can still raise and lower and use Terrain Response so I haven't bothered to do much.
It's also an aftermarket valve block. Sometimes you do only get what you pay for.
adamw412
Sep 13, 2020 09:49 PM
griff black
Jun 23, 2016 05:59 PM
rcharrette
Feb 22, 2013 09:49 AM
NyTelTech
Nov 9, 2009 05:34 PM
