Devon4x4 hidden winch install
Old Sep 10, 2017 | 09:19 PM
abran's Avatar
Default Devon4x4 hidden winch install
I got a decent deal on a Devon4x4 discreet winch mount so I jumped on it.
Its got these tabs tabs that fit into the recesses of the bumper support mount points that allows you to drill 2 sideways bolts(per side)through the frame and the tabs I mentioned.
Then it has 4 bolts that go into the normal captive nuts and 4 extra holes that can be drilled(per side) for mounting. Because of positioning I used 6 bolts per side on the stock mount point and the 2 cross bolts per side. Passenger side was impossible to drill through fully (AC drier in the way) on the top and get a nut on the bolt so I drilled into the tabs, tapped it and threaded a bolt in.
winch is Warn VR12S.
Took me a day and a half. Still not completely happy, but I'll do some adjustments.
Old Sep 10, 2017 | 09:54 PM
Looks good
Old Sep 10, 2017 | 11:10 PM
AB_Colo's Avatar
Looks awesome!
terryth
Sep 14, 2020 08:39 AM
Fivespddisco
Off Topic
Feb 25, 2010 09:00 PM
Willie00d2
Dec 3, 2009 11:44 PM
meltdowndave
Dec 30, 2008 10:12 AM
meltdowndave
May 19, 2008 11:39 PM
