Differential overhaul VS swap
Old Nov 15, 2015 | 05:14 PM
thorgal's Avatar
Originally Posted by TOM R
Guess have me drain it before they pull it so you can see the metal or contaminated fluid
This practice is NOT always true , as I found out .
I always cared about my diffs , changing oils every 25- 30 thou. miles . Never experienced any shavings or black crud on magnetic plug or discoloration in oil and yet my front DIFF started to growl and grind on deceleration indicating a failing left bearing inside diff by half shaft.
I also wanted to add , that my front diff was noise free right until around 165 000 miles or so , so care is important.
Old Nov 17, 2015 | 01:13 AM
DavC's Avatar
Originally Posted by morrisdl
If you are going to spend the money on labor, why not upgrade to an ARB locking diff?
ARB Air Locker - Land Rover LR3 LR4 Front (RD217)
Morris, this is exactly what I am planning for a later date, but at this point I only forsee getting an airlocking rear. MAYBE front down the road but I need the cash for other projects...
Originally Posted by WNYErikDiscoII
I sell that same kit for $260/delivered. All Timken bearings and Corteco Seals
I may PM you at some point, that kit is exactly what I am eyeing.
Originally Posted by clint70
DavC, I would just swap the diff out with another one... you can get a good used diff from eBay or your local wrecker for 80.00 and the swap is simple (ish). I swapped the rear diff in about an hour and a half. Front will be a little more work, but you can do the whole thing your self and save some $$ for other things on your Disco.
Also to help quiet the diff noise down, go with 75-140. It will quiet down the whining... but first make sure that the diff is in good order.
Just a thought, also you can get a truetrac locker for 300 - 400 then do the swap your self.
Either way, good luck and let us know how it goes
Cheers!!
Appreciate the advice, but aren't you talking about a D2, not a D3? I haven't seen diffs for anything less than 900 online (refurbished), and parts trucks for the D3's in scrapyards seem to be rare at this point.
For all others: thank you for your input! Currently strategizing on where to source either a diff, or the parts to replace bearings and seals. Looks like the current plan is to go for broke with a few bearings/seals and if that doesn't solve the problem then I will eventually swap the unit. Following that up I will eventually also replace the rear with a locker from ARB, but for now my objective is to simply address the slightly growling front diff, especially for the high mileage the truck is getting weekly (~500mi)
Old Nov 18, 2015 | 10:54 AM
WNYErikDiscoII's Avatar
Former Sponsor
(~500mi)
I think he was definitely thinking a D2 diff. Ive never seen an LR3 diff go for $80.
And to clarify, I was speaking of the $400 Atlantic British bearing kit that was linked in the original post, not an entire diff. And yes, $260 is what we sell it for.
Old Nov 19, 2015 | 09:14 AM
RipD's Avatar
I think the $80 was for a scrap yard diff.
Old Nov 19, 2015 | 12:32 PM
DavC's Avatar
Even then I have never managed to find a 3 in a scrapyard myself but I have to imagine IF I did find one and they knew what it was it would cost me at least a few hundred.
Disco_Fever
Sep 25, 2011 05:38 PM
Bernie
Mar 5, 2009 10:45 AM
swede7000
Jul 10, 2008 02:18 PM
swede7000
Defender
Jul 9, 2008 11:33 PM
johnkbl
Aug 30, 2007 08:43 AM
