Disable Brake Light on Dash
Old Oct 7, 2022 | 07:57 AM
ketchgould's Avatar
Default Disable Brake Light on Dash
How do I disable the brake light on the dash?
Thanks!
Christian
2005 LR3 V8
Old Oct 7, 2022 | 10:48 AM
douglastic's Avatar
ideally, by fixing the issue that is causing it to light.
this could be as simple as new brake pads and wear sensors.
or as complex as a new parking brake module.
is the light amber? red?
what are your symptoms?
do you have access to a good code reader? (ideally LR specific)
we need more info from you.
Old Oct 7, 2022 | 12:56 PM
ketchgould's Avatar
The light is amber. I know the sensing wire is broken near the caliber. I only want to disable the light and check the condition of my brake pads how we always have, by looking at them.
Is there a fuse to pull?
Thanks!
Old Oct 7, 2022 | 04:55 PM
douglastic's Avatar
it's a $20 part and 15min of your time to do it right.
Old Oct 7, 2022 | 07:59 PM
DakotaTravler's Avatar
You can not disable it, its been covered before. Just a week or so ago actually. The light is triggered two ways, first is via a simple circuit that runs through both sets of wear "sensors". Basically a good ole' dummy light. Secondary is a backup to a parking brake module failure, in case its indicator is out or disabled.
Old Oct 7, 2022 | 08:08 PM
loanrangie's Avatar
New sensor or join the wires together.
Ohhayholly
Jan 12, 2019 09:32 PM
jamestfl
Aug 17, 2015 01:18 PM
Ranu2222
Jul 24, 2015 01:07 PM
BIG
Feb 8, 2010 11:46 AM
kwalford1
Dec 10, 2007 07:48 PM
