Disable Brake Light on Dash
ideally, by fixing the issue that is causing it to light.
this could be as simple as new brake pads and wear sensors.
or as complex as a new parking brake module.
is the light amber? red?
what are your symptoms?
do you have access to a good code reader? (ideally LR specific)
we need more info from you.
The light is amber. I know the sensing wire is broken near the caliber. I only want to disable the light and check the condition of my brake pads how we always have, by looking at them.
Is there a fuse to pull?
Thanks!
Thanks!
You can not disable it, its been covered before. Just a week or so ago actually. The light is triggered two ways, first is via a simple circuit that runs through both sets of wear "sensors". Basically a good ole' dummy light. Secondary is a backup to a parking brake module failure, in case its indicator is out or disabled.
