Discovery 3 2.7 2006 coolant leak
Old Aug 29, 2024 | 02:41 AM
Discovery3_3's Avatar
3rd Gear
Default Discovery 3 2.7 2006 coolant leak
Hello, I have a problem. Recently, after a very hot weather, coolant started leaking quite heavily from my Land Rover. It does not leak when the engine is running, but only after it is turned off. It leaks from around the rear of the engine (by the bulkhead), drips onto the gearbox, and drips down both sides of the gearbox.
It's hard for me to look there because there is little space and the pipe connecting the collectors. The wires that enter the heater stubs are intact.
Does anyone have an idea what it could be leaking from? head?
Old Aug 29, 2024 | 11:12 PM
loanrangie's Avatar
Have you checked the coolant outlet that the rad hose connects to, they are prone to splitting and coolant could run towards the back of the engine.
What country are you in ? , 2.7 was never sold in North America .
Old Aug 30, 2024 | 02:03 AM
3rd Gear
I'm from Poland, Land Rover from Germany, which element in the diagram do you mean? https://www.lrman.ru/img/disco/2287.jpg
Old Aug 31, 2024 | 06:07 AM
loanrangie's Avatar
Item number 5 on the diagram.
Old Aug 31, 2024 | 08:49 AM
3rd Gear
Where is he located? at the back of one of the heads?
Old Aug 31, 2024 | 09:15 PM
loanrangie's Avatar
No, right at the front under the intake Y piece.
doodah92
May 22, 2023 12:58 PM
huggi
Nov 8, 2016 10:34 PM
landroverI
Nov 2, 2015 07:45 PM
tflhund
Dec 30, 2010 09:54 AM
ccvalentino
Jan 6, 2008 08:11 AM
