Discovery 3 2005
Old Apr 21, 2015 | 01:52 PM
Dave Bristow's Avatar
4wd High
Default Fuse box
Originally Posted by Ghaniba
For future help of folks -- Can you expand on what was wrong with the fuse box and what you did to fix it?
Dave
Hi we had an intermittent starting problem. The car would all ways start when it was cold. But as soon as it warmed up and you turned it off and tried to restart it the immobilizer light on the dash would stay flashing and it would not start. Also if the car was left in sun light on a very hot day it would not start. Changing the fuse box has sorted this very annoying intermittent problem.
Old Apr 25, 2015 | 09:44 AM
unseenone's Avatar
Wow, the entire fused box? Maybe it was just a relay, what led to that diagnosis. I am glad it is resolved.
Old Apr 28, 2015 | 04:01 AM
Oasisplayer311's Avatar
Seems like it would have been more of a relay issue than an entire fusebox failure. Was this diagnosed by a dealership or Independent shop?
Old Apr 29, 2015 | 09:52 PM
unseenone's Avatar
as a side note, I have run into this a time or two before, and it turned out to be a bad battery, so by all means, when you shut it off, check the voltage. A couple other culprits certainly could be the starter, starter cable, and I guess the fuse box...
jwmillerss
Aug 17, 2012 11:04 PM
mazinqureshi@tiscali.co.uk
Jul 7, 2009 07:51 AM
ericschramm2000
Freelander
Oct 17, 2008 01:43 PM
STi NUt
Appearance & Camping Set Ups
Mar 12, 2006 03:15 AM
Lighting90
Off Topic
Jan 2, 2005 04:56 PM
