Do LR3 wheels fit on Lr4s?
Old Apr 23, 2021 | 09:32 PM
K9Hexe's Avatar
Default Do LR3 wheels fit on Lr4s?
Ive got 18" wheels on my Lr3 and Im looking to upgrade to LR4. Will my Lr3 18s fit on Lr4s?
Old Apr 23, 2021 | 10:32 PM
houm_wa's Avatar
...how is that an upgrade?
Old Apr 24, 2021 | 10:54 AM
5280LR3's Avatar
I read it as he's going to take his 18" LR3 wheels and attempt to install them on a LR4. I don't know about caliper sizes on the LR4... probably gonna need a trial fit. I see the LR4 brake calipers are different part numbers than the LR3, so they may be larger or a different shape. I'm sure the wheels would bolt to the hub, but the wheel may rub on the caliper.
Old Apr 25, 2021 | 08:19 PM
loanrangie's Avatar
Not sure what engines you guys got in the D4 but for rest of world it goes like this - minimum sizes for D3 models petrol V6 and 2.7TDV6 17" , V8 18' , early D4 with 2.7 TDV6 18", 3.0ltr TDV6/SCV6/V8 19".
So i'd say that was no.
Old Apr 26, 2021 | 11:26 AM
douglastic's Avatar
I've read they will fit with 30mm (or 1.25") spacers.
Old May 9, 2021 | 09:40 PM
K9Hexe's Avatar
Thank you guys. Yes I am asking because I have 18" wheels with larger tires on my LR3 as I am running Johnson Rods. I am looking to make the jump to a 2016 LR4 but of course it comes with 19" wheels. Id like to just just swap them if possible to avoid buying new wheels for the LR4.
Old May 9, 2021 | 11:21 PM
loanrangie's Avatar
Pretty sure you need to shave the calipers even with spacers,i'd stick to the 19's or get aftermarket 18's.
Old May 10, 2021 | 01:16 PM
houm_wa's Avatar
Default Oh I knew what you meant...
I just don't think the LR4 is an upgrade! 😁
Old Feb 14, 2024 | 08:47 PM
archaeology_student's Avatar
Do the LR3 18” wheels fit the earlier LR4 with the 5 Litre V8, or would spacers be needed?
I recall being at the parts department at the dealership and they said the 18’s are a straight swap.
Old Feb 14, 2024 | 08:57 PM
loanrangie's Avatar
Not sure about the 5ltr but they fit on the 4.4, i think 5ltr has bigger breaks again.
gillart
Feb 14, 2024 12:19 AM
LR03NJ
Apr 16, 2018 10:10 PM
gtokid
Oct 31, 2017 05:42 PM
Kooner
Aug 28, 2007 04:51 PM
