Door lock actuator
Old Sep 16, 2015 | 11:04 PM
abran's Avatar
Default Door lock actuator
Just bought a new remote( old one wasn't working). Coded to my wife's LR3 and it works great, but the drivers door doesn't lock.
Is this a simple faulty door lock actuator? Same as a D2?
Also, does the window frame have to come out to swap it?
Old Sep 17, 2015 | 11:39 AM
unseenone's Avatar
The window will "release" from the holder. The assembly is built in with the latch that you swap out. There is a plastic clip once you take the door panels off that gives you access.. it's in the manual I sent you. The bugger is getting the cable back on during reassembly.
Old Sep 17, 2015 | 02:02 PM
abran's Avatar
OK, Gonna check the manual. Any idea which section/document?
Thanks
Old Sep 18, 2015 | 04:16 PM
unseenone's Avatar
501-14 Handles, Locks, Latches and Entry Systems
Front Door Latch (76.37.12)
Old Sep 19, 2015 | 12:21 PM
abran's Avatar
Awesome! Tackling today.
Old Jan 24, 2016 | 05:34 PM
slanginsanjuan's Avatar
definitely read that the window does not have to come out.
it sucks to have to buy a new actuator...or two.
also read that you can just replace that motor..
i bought springs cause they were cheap and it would have been nice to only have to replace those.
Brad S1
Jan 23, 2018 09:02 AM
kristofferzen
Sep 10, 2015 02:11 PM
