driver's seat heater not working
Old Dec 24, 2012 | 06:22 PM
TElam's Avatar
Default driver's seat heater not working
any thoughts? I checked all obvious fuses(unless there's one I dont know about) button still works and lights up but nothing happens when it's on. all other seat heaters working
Old Dec 24, 2012 | 07:44 PM
Rovin4life's Avatar
probably needs a new seat heater. the job isn't too bad. you need a t40 with an extension to take the bottom seat out and then you have to remove the seat bottom from the seat leather by removing the parts that are attached to the seat and then cut the hog rings out and remove and install a new pad and then install new hog rings. You will probably need twenty. You can buy them at napa or any dealer. They are called hog rings. You need a hog ring pliers as well to make it easier to install.
Old Dec 25, 2012 | 10:47 AM
TElam's Avatar
thanks for that reply. what exactly are 'hog rings'? do they hold heating element in place? if I go try to find some I just wanna make sure I'm looking for the right thing. Thx!
Old Dec 27, 2012 | 11:52 AM
bbyer's Avatar
Default Metal rings to hold the upholstery.
Below is per a Google search - picture is ,,,,, and one jpg even shows the pliers.
hog rings - Google Search
Old Dec 27, 2012 | 12:40 PM
Rovin4life's Avatar
the heater is glued to the cushion, the seat leather over it is held on with hog rings.
Old Dec 27, 2012 | 07:00 PM
TElam's Avatar
any particular kind of adhesive should be used when isntalling new heating element?
tsuyoi
Sep 22, 2020 10:37 AM
sleepy1525
Mar 12, 2015 03:32 PM
Just For Fun
Aug 16, 2013 09:27 AM
jfall
Jul 23, 2012 04:32 PM
preple
Oct 19, 2011 04:00 PM
