DSC issues
DSC issues
I recently had the front differential replaced with a used one due to the high expense. After I got it back - when I hard accelerate taking a left, right or straight, the DSC light comes on and I can hardly control the vehicle as it seems that it pulls back or forth. It eventually kicks off, but it takes about 10 seconds or so for it to reset. This cannot be normal, any thoughts?
I've experienced similar behavior due to poor alignment or wheel/tire changes.
When you floor it, acceleramators to into crazy mode to figure out what's going to bust loose first. Any slight issue with steering angles or suspension geometry will throw off the sensors and computers.
There was one corner on my way home from work that would ALWAYS randomly trigger DSC. Uphill left-hand turn off-camber unloading suspension. I just started pressing the button to disable it before the turn lol. Never even an inclination of an issue - totally a calibration or alignment issue.
DSC is important though, totally saved my butt in my RRS.
When my front and rear suspension bushings were getting sloppy it would trigger on turns that would otherwise be easily doable.
I would get underneth and flex your suspension bushing well to see if you are developing play. Becasue of the weight of the truck, they seems to get dangerously worse rather quickly... at least that was my experience.
NhudeST
03-14-2011 01:50 PM
Brad S1
09-02-2008 11:03 PM
