DTC P0171 and P0174 Too Lean
Old Feb 8, 2016 | 03:56 PM
pgoodrich's Avatar
Default DTC P0171 and P0174 Too Lean
Hello,
I just received these codes the other day. I checked for any leaks but didn't find any. I could hear the PCV air flowing but no leaks. Two years ago I replaced the PCV and MASS for p0171. Now two codes are present. Time for a new MASS again or ...
Some logs from IID tool. What do you all think?
File Type: pdf
File Type: pdf
Old Feb 8, 2016 | 07:07 PM
thorgal's Avatar
Lean codes could mean anything...
Check for any leaks on harmonic air intake, air filter screws, O straps,oil cap and believe tr or not , dipstick's o ring.OnLR3 MAF sensor is usually associated with PO101 code.
Old Feb 8, 2016 | 07:23 PM
jafir's Avatar
Dirty injectors
Old Feb 8, 2016 | 08:43 PM
pgoodrich's Avatar
Originally Posted by jafir
Dirty injectors
Do you clean with bg44k or use special cleaner directly into the fuel rail?
Old Feb 8, 2016 | 08:58 PM
jafir's Avatar
Both.
discodan2001
Dec 20, 2008 07:41 PM
utunes
Apr 20, 2008 12:55 PM
ToddinLou
Freelander
Jan 28, 2008 02:36 PM
rirover
Jul 5, 2006 11:21 AM
mikedemet
Apr 13, 2006 01:05 AM
