Screw Thread Size ??
Old Feb 3, 2016 | 05:50 AM
gmfain's Avatar
Default Screw Thread Size ??
Anyone know the Screw Thread Size one the Auxiliary threaded hole on the Battery Connector?
Thanks,
Mitchell
Old Feb 4, 2016 | 12:28 AM
Zelatore's Avatar
For some reason I think it's a 7mm but that's really a WAG. I suppose I could check, but my Rover is 75 miles away until the weekend.
Old Feb 4, 2016 | 04:41 AM
gmfain's Avatar
this my third day of searching, I found this:
DISCO3.CO.UK Photo Gallery - Traxide Dual Battery install in LHDrive/Main starting battery showing 1/2" hole drilled for power cable egress
In the text label it states, "The cable bolts to a spare 6mm threaded hole in the OEM battery cable end; "
I'm gonna stop at the hardware store this weekend and give 6mm a try.
Thank you for responding!
cheers,
Mitchell
Old Feb 5, 2016 | 11:40 AM
Zelatore's Avatar
Well, FWIW I just checked mine ('07) and it's an M8x1.25, so you might want to pick up a couple while you're there just to save an extra trip.
Old Feb 8, 2016 | 04:44 AM
gmfain's Avatar
Thanks Don, I didn't make it to the hardware store yet. I believe 8mm is correct though. I was able to check the ID, it was 6.7mm, which is the exact tap drill size for 8mm.
Thanks for checking yours for me.
Mitchell
Old Feb 9, 2016 | 05:10 AM
gmfain's Avatar
And the winner is M8 X 1.25mm.
Thanks for all the views and replies!
Mitchell
Coyote
Apr 5, 2017 09:10 PM
akbarkhan
Aug 18, 2013 01:29 PM
antisoshal
Jul 5, 2011 01:53 PM
ttrn
May 21, 2011 06:23 AM
lipadj46
Aug 17, 2009 10:08 AM
