Dumb Q - Bleed to change bleed "T"?
Old Jul 7, 2017 | 12:14 PM
DavC's Avatar
FYI having bled the entire loop, the bleeder T is entirely unnecessary. You could stick a bic pen body in there for all that it is needed.
Every dealer tech I asked about it just does it the old way.
Old Jul 7, 2017 | 08:36 PM
Best4x4's Avatar
I replaced my 06 HSE T with a straight Brass piece. No more brittle "weak link" in my cooling system & when I removed it "some" coolant did come out. I simply removed the T, replaced it with the straight brass piece used two new hose clamps and called it a day, and I didn't bleed the cooling system. Zero issues and that was nearly 8k ago.
Old Jul 14, 2017 | 09:34 AM
djkronik57's Avatar
I'm not sure what the PO or maybe my mechanic did, but I've never had a bleeder valve. The break in the hose where it should be is literally overlapped (one end inside the other). The PO seemed to be wise to common issues based on maintenance records, so wouldn't be surprised if it was something they did. Doesn't leak, so if it ain't broke...
jycsalas
May 23, 2019 03:02 PM
collin Barrows
Aug 28, 2011 07:13 AM
JavaDiscoII
May 29, 2010 04:33 PM
armlock
Dec 29, 2007 07:20 PM
FORDSTANGER
Jun 7, 2005 06:02 PM
