Electrical issues and water with codes
Old Mar 4, 2024 | 03:44 PM
TravelingLR3's Avatar
3rd Gear
Default Electrical issues and water with codes
Hello,
Water has been sitting in the passenger and driver side sills and got on the center console wiring as well (broken sunroof and clogged drains). The radio volume doesn't work, terrain response doesn't work but all lights are on, key fob doesn't unlock and lock (tried splicing the green wires, no luck, might be corroded all the way through the wire), and "D" is illuminated all the time on gear shifter. I have tried searching and reading but nothing I have tried has worked so far. I replaced the terrain control with all the switches, tried splicing the green wires for the key fob. Is there one specific issue for all, or is it multiple issues? Where to start?Audio System
  • U1A03-62 (2B) Vehicle configuration parameter - Algorithm based failure - signal compare failure
    ( on 04-03-2024 11:31:50 at 90399 mi )
Body Control
  • B1B02-28 (2F) Low frequency coil - General signal failure - signal bias level is out of range/zero adjustment failure
    ( on 04-03-2024 12:26:22 at 90397 mi )
  • B1C82-14 (2E) Headlamp washer relay coil circuit - General electrical failure - circuit short to ground or open
    ( on 04-03-2024 11:29:50 at 90397 mi )
  • B1C96-13 (2F) Alarm LED circuit - General electrical failure - circuit open
    ( on 04-03-2024 12:26:31 at 90397 mi )
  • B1D14-15 (2F) Interior lamps 2 circuit - General electrical failure - circuit short to battery or open
    ( on 04-03-2024 12:20:38 at 90397 mi )
Engine Petrol
  • U0138-00 (2A) Lost communication with all terrain control module
Instrument Pack
  • U0138-87 (2F) Lost communication with all terrain control module - Bus signal/message failure - missing a message
Suspension
  • U1A13-87 (2F) Lost communication with all terrain control module - Bus signal/message failure - missing a message
    ( on 04-03-2024 11:29:18 at 90399 mi )
Transfer Case
  • P1807-00 (2F) Four-wheel drive high ratio - short circuit to ground
    ( on 04-03-2024 11:29:19 at 90399 mi )
  • U0138-86 (2F) Lost communication with all terrain control module - Bus signal/message failure - signal is invalid
Vehicle Dynamic
  • U0138-87 (0B) Lost communication with all terrain control module - Bus signal/message failure - missing a message
    ( on 04-03-2024 12:26:30 at 90399 mi )
TravelingLR3
Old Mar 5, 2024 | 09:08 PM
loanrangie's Avatar
I can only advise on the gear shifter issue, it'll need to be replaced as the PCB on the side will have shorted out. I flooded the console when i left the sunroof open and we had a flash summer storm, managed to dry everything else out and not have any further problems but the shifter wasn't so lucky.
I would have thought that replacing the switch packs on the console will have fixed it but must be further along the harness.
jbullock78
Oct 16, 2024 10:34 PM
NJOverland
Oct 24, 2022 09:19 PM
Rufflyer
Aug 12, 2019 07:45 AM
Philip Chan
Jul 5, 2019 05:53 PM
