Electronic Parking Brake (EPB)
Old Sep 4, 2022 | 02:04 PM
Taoss's Avatar
Default Electronic Parking Brake (EPB)
HI All I had to recover my wife when the parking brake was stuck (pulled the cable inside the car near the EPB button.
I have since completely replaced all rear brake components (Shoes+springs etc/Disks/Pads) I followed the instruction to the letter to fit them with all torque and process followed for calibration.
Unfortunately I am still stuck with the fault "C1 A53-68 Electronic parking brake latching failure. emergency release has been activated"
  1. I have tried the process of Press Brake 3 times (hold on 3rd) --> Press EPB button UP 4 times --> Press EPB button down 3 times)
  2. I have also tried the Brake Service options in my Foxwell scanner tool to re-latch etc.
What do I need todo to get the LR3 out of "emergency release has been activated" and return it to normal operation.. BTW I have also reset all fault codes.
Any help would be appreciated.
Old Sep 5, 2022 | 06:54 AM
mx468's Avatar
Have you tried disconnecting the battery and try a hard reset? Here's a link on how to.
DISCO3.CO.UK - View topic - Hard Reset
Old Sep 5, 2022 | 01:12 PM
DakotaTravler's Avatar
If you replaced all the components while it was emergency released, then there is likely your issue. Your cables are likely way too far extended out and the module can not retract them back enough because you have installed/adjusted to the cable position in release position. You may have to release the cables at the brakes so they can retract then readjust.
Old Sep 5, 2022 | 07:13 PM
Rufflyer's Avatar
Did you use an "unjamming: procedure? When you pulled the emergency cable in the console, you released a small clip on the left side of the gear assembly and that separated the two cables from each inside the parking brake module. Normally it can be reconnected with the unjamming procedure from a diagnostic tool like a Gap Tool or the Land Rover T4. it not, you will need to climb up there pull the cover off and reconnect the two parts. If the gears in the module get stripped, you will be removing the unit and repairing the gear set.
IF you do need to remove the module. and this is important. pull a stiff wire along the cable on both sides so you know the proper routing of the cable for installation. If not, you will likely install it three times to get it right (ask me how I know)
Lainie
Aug 7, 2022 01:23 PM
amcarroll
Discovery Sport
Jan 29, 2022 09:22 AM
twcord
Sep 30, 2021 08:17 AM
jmartosella
Range Rover Evoque
Dec 26, 2020 07:10 PM
bamaboy473
Aug 3, 2012 06:33 AM
