Enable Nav input on the go by cutting off vehicle speed signal to Nav module?
Old Feb 14, 2011 | 02:31 PM
perkj's Avatar
Default Enable Nav input on the go by cutting off vehicle speed signal to Nav module?
Hi All,
I have a 2008 LR3 that can't use the Nav Hack to enable the Nav Input on the go b/c of the firmware update. I found the wire diagram for the main Nav Module and I see there is a vehicle speed wire going from the ABS system to the main Nav module. My thought here is to put an in-line switch onto this wire feed so when in the off position no speed info will be sent. I'm assuming its this feed that tells the Nav to enable/disable the buttons by moving.
Anyone done this? Am I on the right track?
See page 5 of the wire diagram:
http://lr3tips.files.wordpress.com/2...mentsystem.pdf
Old Oct 2, 2011 | 12:47 AM
bjwhite's Avatar
So did you try it? Did it work?
Mecevans
Aug 9, 2015 02:30 PM
LRLawyer
Mar 17, 2014 10:22 PM
Jay_sathe
Feb 13, 2014 08:14 AM
filmhog
May 16, 2012 04:57 PM
msandona
Feb 16, 2010 09:04 PM
