engine fan
...but I just had "roaring fan" and hold to the 'don't sweat it' philosophy but making a few observations, wonder if a block heater could be to blame. It's been cold up here (27F - 37F) but not too cold. I sometimes plug it in on a timer just because I can. Tonight it was 37 and the heater had been on for maybe 30 minutes but my real question is: could this trick the ECU or coolant sensors? I drove around and it heated up some but my temp gauge was still in the lower 1/3 of the range. (The CC was blowing warm air on my feet). So I pulled over and shut it off. After a minute or so fired it up again. The temp gauge went to normal range right away. The fan gave me one more road then it all went normal. Idle was a little high in N until I rebooted too.
Any thoughts?
Any thoughts?
I chuckled to myself when I read this...
Up here in the land of the ice and snow, vehicles don't get plugged in til it's below 0F or colder. It was -20F here this morning and the truck started right up. A brief (2-3 sec) howl from the PS pump and all was good.
Best feature on these trucks, imo... heated front windscreen. Brilliant for freezing rain or heavy frost.
This thread reminded me of a oil pan heater I bought for my old 95 E300D. It had a 4"x5" 3M adhesive heater pad and a 3-4' length of cord with a plug. What I liked about this setup was it was heating up the oil in the pan and that heat was naturally radiating up into the engine block. Will see if I can find a link...
I will keep an eye on the fan behavior. It does this once in a while and everything else seems normal. Thermostat isn't all that old....but can't rule it out.
twilightcall
Mar 4, 2018 06:55 PM
rover1978
Sep 26, 2009 09:05 PM
