engine fan
Old Dec 28, 2017 | 08:42 AM
  #21
BritishautoworksSD's Avatar
Originally Posted by houm_wa
...but I just had "roaring fan" and hold to the 'don't sweat it' philosophy but making a few observations, wonder if a block heater could be to blame. It's been cold up here (27F - 37F) but not too cold. I sometimes plug it in on a timer just because I can. Tonight it was 37 and the heater had been on for maybe 30 minutes but my real question is: could this trick the ECU or coolant sensors? I drove around and it heated up some but my temp gauge was still in the lower 1/3 of the range. (The CC was blowing warm air on my feet). So I pulled over and shut it off. After a minute or so fired it up again. The temp gauge went to normal range right away. The fan gave me one more road then it all went normal. Idle was a little high in N until I rebooted too.
Any thoughts?
Sticking thermostat? I would maybe measure actual temp at the radiator, thermostat crossover and temp sensor with a laser temp gun. Compare reads to electronic signals if this happens again.
Old Dec 28, 2017 | 10:27 AM
  #22
EastCoast's Avatar
I chuckled to myself when I read this...
Up here in the land of the ice and snow, vehicles don't get plugged in til it's below 0F or colder. It was -20F here this morning and the truck started right up. A brief (2-3 sec) howl from the PS pump and all was good.
Best feature on these trucks, imo... heated front windscreen. Brilliant for freezing rain or heavy frost.
Old Dec 28, 2017 | 10:35 AM
  #23
EastCoast's Avatar
This thread reminded me of a oil pan heater I bought for my old 95 E300D. It had a 4"x5" 3M adhesive heater pad and a 3-4' length of cord with a plug. What I liked about this setup was it was heating up the oil in the pan and that heat was naturally radiating up into the engine block. Will see if I can find a link...
Old Dec 28, 2017 | 10:38 AM
  #24
EastCoast's Avatar
Here it is...
Amazon Amazon
Old Dec 28, 2017 | 10:56 AM
  #25
houm_wa's Avatar
Default I know I know...
Cold for Washington is not truly cold. I added the block heater prior to a trip to the Yukon Territory...and I didn't consider those that stick magnetically to the oil pan because of the big aluminum skid plate that covers mine.
I will keep an eye on the fan behavior. It does this once in a while and everything else seems normal. Thermostat isn't all that old....but can't rule it out.
jafir
Feb 10, 2017 11:08 AM
Eak69
Apr 6, 2010 04:50 PM
rover1978
Sep 26, 2009 09:05 PM
jmt
Jan 14, 2008 05:01 PM
