Engine Revved High at start up and when put into drive
Old Sep 21, 2017 | 06:25 PM
ljdiscovery's Avatar
Default Engine Revved High at start up and when put into drive
2006 Range Rover Sport 4.4 liter V-8, 29,000 miles. The engine has been running great! Today I drove to a lunch meeting. After the meeting I started the truck and it was revving high, idle was kind of like when starting on a cold morning, maybe a tad higher. I was a bit preoccupied and put the truck into reverse, foot on the brake as I normally do. Idle was high enough that the truck started moving backwards when I put it in reverse, even with my foot on the brake. I pressed the brake harder and the truck stopped backing up, but it seemed to rev even higher. It seemed like the throttle was stuck on. I turned the ignition off and put it back in park. I started it again a few seconds later and idle was normal. This was a real safety issue. Any idea what is going on? Has anyone experienced this type of issue again.
thanks Phil
2006 Range Rover Sport HSE
2005 Land Rover LR3 HSE HD
Old Sep 21, 2017 | 09:47 PM
houm_wa's Avatar
Wait...29,000 miles? Is that a typo?
Old Sep 22, 2017 | 08:18 AM
No typo. Long story. Sat from 2007 to last year. Phil
Old Sep 22, 2017 | 09:25 AM
abran's Avatar
I'd start by cleaning the throttle body and reset engine adaptions.
Old Sep 28, 2017 | 09:38 AM
Yankee427's Avatar
4wd High
I have a 2006 LR3. Mine would rev at high levels and was racing while idle. It was a very hard start and would stall sometimes. About two months ago I did a full cleaning of the Mass Air Flow Sensor and Throttle Body.
After cleaning those, the idle sounds much better. I would give that a try first.
Old Sep 28, 2017 | 11:30 PM
Thanks. Fun weekend ahead. Phil
jmha106
Jun 27, 2016 08:27 PM
Mikeyboi
Freelander
Mar 4, 2015 08:47 AM
bamaboy473
Feb 15, 2013 01:40 PM
freelanderjames
Freelander
Dec 24, 2008 10:18 PM
theworks001
Dec 8, 2008 09:47 AM
