EPB Cable
Old Jan 26, 2024 | 12:40 PM
houm_wa's Avatar
Default EPB Cable
Hi all,
I have a shop trying to replace the EPB cable on the driver's side. Does the exhaust have to be removed? Is there a better/easier way to do it?
Thanks,
HOUM
Old Jan 26, 2024 | 09:59 PM
DakotaTravler's Avatar
Those can be hell to replace. But if I recall, the spare needs to be removed and it can be accessed up through that way. The EVAP canister may be in the way too. But basically I think you can get it from up and over the crossmember more easily than from straight below. But be warned, they are often fused to the brake shield and often do not come off well. When installing new, use plenty of something that can prevent corrosion.
Old Jan 27, 2024 | 12:07 AM
houm_wa's Avatar
Thanks Dakota! I'll pass that along to the shop doing the job. The prior cable must have been fused as you mention; they had to cut it in order to get the hub out - getting that wheel bearing changed - and now getting the new cable back in is....a chore.
Wayne12
May 4, 2022 03:25 PM
ShadowMerchantBC
Jan 26, 2017 05:44 PM
georgehs1
Feb 5, 2016 01:42 PM
toofaroffroad
Dec 30, 2012 11:51 AM
ColoDisco
Jul 26, 2011 06:28 PM
