EPB error when water got into sunroof
Old Jun 19, 2020 | 06:12 PM
krazi3azn's Avatar
8th Gear
Default EPB error when water got into sunroof
Accidentally had my sunroof open and water got all over the console. It seems everything works except the electronic parking brake.
The light keep flashing. I got a new switch but it has not fixed the error. What should I do?
Old Jun 19, 2020 | 08:00 PM
DakotaTravler's Avatar
Check the fuse? Maybe the switch shorted it out. Otherwise need codes so it can really say what the issue is.
Old Jun 20, 2020 | 08:39 PM
Globetrotter448's Avatar
There is a connector under the centre console that does not like to get wet
Old Jun 22, 2020 | 04:57 PM
krazi3azn's Avatar
8th Gear
I checked the fuse in the engine bay. No issues is there another one?
the code is u2002-01 which is the switch. Might be the wiring under it
krazi3azn's Avatar
8th Gear
yea I tried the new switch and the old switch in my friends LR3. It looks to be the wiring under the console. Do you have any more info about it? Do I just get a new connector?
Old Jun 22, 2020 | 05:22 PM
Generally, you can dry it out and then use some contact cleaner on it and it normally comes good unless its corroded. Don't forget to clear codes afterwards.
Old Jun 24, 2020 | 08:35 PM
krazi3azn's Avatar
8th Gear
So I check the fuses and all of them seem to be fine.
I thought maybe it was a coincidence and checked the wires from the switch in the rear wheel and none seem to be broken.
I noticed today that it won’t go into low range gear or to access height (lower ride height). The off road height works tho.
Im not too concerned with replacing the center console switches right now but does the EPB have anything to do with them? Since the switch or the wiring that I checked so far are good
Old May 6, 2023 | 06:22 AM
wajohnson92's Avatar
I have just made this same error! Left the sun roof open. Did you dry out the connector? Did that work? If not, what happened! Thanks
za105
Sep 16, 2019 03:28 PM
kmelesky2
Feb 27, 2017 05:33 PM
jasonrusso
May 16, 2011 07:51 PM
marlymarl
Apr 12, 2010 02:00 PM
Hedleyj
Jan 19, 2010 03:24 PM
