EPB Fault - Longitudinal Acceleration Sensor
Hey all,
'05 LR3, 80k miles. I've had an amber parking brake warning light for a while that resets each time the vehicle is shut off, but comes back after driving for a bit.
Fault info from Gap tool:
Parking Brake
• C1A40-02 (A8) Longitudinal acceleration sensor - General failure information - general signal failure
I have reset the fault and attempted to perform the longitudinal acceleration sensor calibration routine per procedure, and it fails each time (says "Routine Failed E 7").
Does anyone know anything about this sensor, like where on the vehicle it is located? I have searched the workshop manual, and the only reference I can find to it is in the DTC list. I would like to attempt to just swap it out and see if that fixes my issue.
Thanks for any help!
Parking Brake
Do you have the RAVE manual?
It appears that the sensor would either be one of the microswitches in the EPB switch in the console (you could swap in a new one to test this, not too much money), or it would be in the actuator assembly under the truck.
See attached. For reference this is section [206-05 Parking brake and Actuation]
So out of curiousity, would you or someone else be willing to use your Gap tool and take a look at the live values display for your longitudinal acceleration sensor? What I am curious about is your value while the vehicle is at rest. Mine reports a value of between -380 to -390 ms2 while at rest.
Thanks!
kbarker27
Oct 13, 2023 04:03 PM
