Falcon website out of T bleeder valves? Whaddya think of this?
Old 09-12-2021, 09:03 PM
svs's Avatar
svs
svs is offline
Default Falcon website out of T bleeder valves? Whaddya think of this?
I copied what someone else did on another thread here. He used a 1/4 pipe tee fip, (2) 3/8 x 1/4 mip hose barbs, and a 1/4 square hose plug. He said it worked fine. My other LR3 has the Falconworks brass T bleeder. My question is ~ will those side barbs loosen and unscrew? The whole point being that the OEM bleeder disintegrated over time unexpectedly. I dont want the irony to be this one unscrewing and leaking coolant and...you know the rest - Whaddya think guys? (For my 2nd LR3)
Old 09-12-2021, 09:19 PM
DakotaTravler's Avatar
Whatever works, works. Its just a fitting that need to hold up to only 16psi or so.
svs (09-12-2021)
Old 09-14-2021, 02:14 AM
loanrangie's Avatar
Put some thread sealer on the threads.
Old 09-14-2021, 04:31 PM
douglastic's Avatar
I chose one of these from the hardware store for a couple $
I also have a new OEM LR027661 as a backup, if I ever need to bleed from that location
Old 09-14-2021, 04:50 PM
svs's Avatar
svs
svs is offline
Default Paranoid it'll unthread.
Hiya. I picked up some Permatex Red RTV high temp silicone. Will that work? Thx. Doh!! I picked up silicone gasket. I think I need the thread lock seal instead.
svs's Avatar
svs
svs is offline
Hiya. I picked up some Permatex Red RTV high temp silicone. Will that work? Thx. Doh! This is the wrong one. I need thread sealant / lock.
Old 09-14-2021, 04:55 PM
svs's Avatar
svs
svs is offline
Default So you're the guy who went full pipe ~
I also have a new OEM LR027661 as a backup, if I ever need to bleed from that location.
I read in one of the threads on this similar topic that someone put in a straight brass pipe. Maybe that was you. I suppose that's more solid than a bic pen tube.
douglastic (09-15-2021)
Old 09-15-2021, 10:43 AM
Gnomadf's Avatar
or they seep. And by the time it's cool enough to redo it with sealer you've compoletely forgotten about it and moved on to other chores.
Old 09-15-2021, 07:58 PM
steevo67's Avatar
The homemade brass tee setup you have there will work just fine and will likely never fail again, but is overkill and a bit more expensive than necessary in my opinion. When I priced out that exact setup to fix my LR3 a couple years ago, it added up to over $20 in fittings (maybe I shop at the wrong places). I've never used the upper bleeder so I "straight piped" it like douglastic described above and have never had an issue.
Old 09-16-2021, 07:27 AM
Gnomadf's Avatar
If you have a local Rover dealership it's likely cheaper to get the part from them but if you have to add shipping it's probably going to be $20 anyways.
The straight pipe idea is really a better way to go, didn't think of that at the time I needed my tee-when mine went, I had smelled some coolant, saw the tee weeping and said "hmm", touched it and it exploded at my touch. I was liucky to not get coolant burns.
Quick Reply: Falcon website out of T bleeder valves? Whaddya think of this?
