Flag mount
Old Mar 23, 2023 | 04:37 PM
lenzda's Avatar
Default Flag mount
Any ideas for mounting a front bumper flag for sand dune adventures? Only caveat being no bull bar or steel bumper - totally stock front end.
Old Mar 23, 2023 | 05:31 PM
DakotaTravler's Avatar
I have not done it yet, but I was myself planning to drill a small hole (1.5" or so) in the bumper cover right above the metal real bumper at a corner. Then on the metal bumper weld on something to thread in a rigid 16" pole which the flag pole would attach to. I want the rigid bit to prevent the flag pole from whipping into the headlight cover or edge of the hood. When not in use a hold cover could snap in place or simply leave it as it. Came to mind when I decided I need to mount two short poles in front of the grille for winch rope storage when on the trails - hate winding that thing back in every time.
Old Mar 23, 2023 | 07:45 PM
loanrangie's Avatar
Can you use a tow hitch adapter for the rear, still visible over dunes.
Old Mar 24, 2023 | 10:02 AM
Rufflyer's Avatar
Default Front mount
This is for a much heavier antenna mount, but the process could work for a light flag as well
It is mounted on top of the metal "bumper"
I am looking for some pictures of it tore apart and aill update when I find them.
Jeff
Old Mar 24, 2023 | 06:46 PM
That is exactly what I was picturing but for a flag more to a corner. But for my winch I plan to use that exact spot on each side. Then I can loop the cable around them when wheeling on the trails.
Old Mar 25, 2023 | 09:28 AM
Rufflyer's Avatar
Default Installation pictures
I have the factory winch and it does not affect this mount.
Front view of bumper mount
Top view of bumper mount
Old Mar 25, 2023 | 10:09 AM
lenzda's Avatar
Fantastic. This is probably the best solution, I’ll make mine threaded so I can remove the post when not in use. I’ll need to figure out a “cap” to cover up the hole when not in use.
thanks for the photos. Did your rig come with the factory winch? Or did you source it from somewhere?
Old Mar 26, 2023 | 07:36 AM
Rufflyer's Avatar
Default Threader is better
I would recommend a threaded pipe with a floor flange mounted on the top of the bumper as I did. My problem is the antenna is 9 feet long and weighs 12 pounds so any pipe large enough to support that had a fllow flange that was too big to fit under the bumper cover. My pipe is 1 1/4 inch dia if you go with a 1/2 or 3/4 in pipe you should be fine. as for the "cap", I would recommend a rubber gasket that matches the size of hole you drill with a hole saw or drill bit.
I got the winch from Devon 4x4 in the UK. I would say, that unless you need a new factory winch, such as a G4 build or some such, I would not recommend one because they are super stupid expensive, almost impossible to find, and come with a steel cable. the kit came in a 2 x 2 x 3 ft wooden crate that weighed 94 kg. (you need a scientific calculator to work the formula to even guess the shipping cost) If you need a winch (anything that is not a mall crawler needs a winch) there are many other cheaper easier winch and winch mounts out there now.
Jeff
11chuck
Oct 13, 2020 09:37 PM
gulfstream69xr7
May 6, 2016 04:51 PM
redjeep
Jun 30, 2015 05:45 AM
Rover_Hokie
Nov 17, 2012 11:26 AM
mdf27
Feb 16, 2011 03:51 PM
