flashing parking light after shut off
Old Jun 12, 2022 | 11:08 PM
toofaroffroad's Avatar
Default flashing parking light after shut off
OK ,here is fun one. 2005 LR3 approx 150 miles. No codes showing on my GAP regarding parking or parking brake but....occasionally I'm getting a flashing red parking symbol on my dash right after I turn the truck off. It seems to flash for approx 1 minute then stops. Also, it's not consistent. It seems to do it maybe every 5th time I turn the truck off. Any ideas?
Side note, I never use my parking brake.
Old Jun 13, 2022 | 12:36 AM
DakotaTravler's Avatar
No codes for anything?
Did you edit the CFF to auto-engage the parking brake?
When was the last time it was serviced? The parking brakes require regular service as the system is always active using a cable tension monitor. If the system is not serviced, it can fault. You may be in the pre-fault area of things.
Old Jun 13, 2022 | 10:11 AM
Thanks for the response. Parking brake is not set to "auto". I've had my truck for 6 months now and I never use the parking brake. It's been activated maybe 1/2 a dozen times. The light came on last night when I got home flashed red for about 1 minute after shut off then went away. I'll check my GAP again when I'm home from work today.
Old Jun 13, 2022 | 05:28 PM
Yeah, codes auto-clear depending on severity. You may need to pull codes right when its flashing. But like I said, it could be just a warning right now that something is not right and not really generating a code. The parking brake system has several international standards/rules the design must follow with indicator lights. Example, if the main fuse is pulled for the parking brakes, the brake pad wear light then illuminates as a backup to the parking brake system.
Oceanguy33
Mar 5, 2022 07:11 PM
rlj174
Jan 11, 2022 06:57 PM
twcord
Sep 30, 2021 08:17 AM
mreloc
Jun 13, 2021 04:18 PM
jmartosella
Range Rover Evoque
Dec 26, 2020 07:10 PM
