Front Control arms only or rear?
Old 03-12-2018 | 07:13 AM
Noah Woodcock's Avatar
Default Front Control arms only or rear?
Hello all, I need front lower control arms for my 3, if the fronts are bad should I also do the rear lower?
what about the front upper? I am leaning towards doing the front lower and upper both and leaving the rear, is that what I should do?
I know my post is scattered and I appologize
Old 03-12-2018 | 10:18 AM
abran's Avatar
Uppers usually go when off-roading more. The lowers are standard during street use.
If you want to refresh the whole front do lowers, uppers, inner/outer tie rod ends, sway bar bushings, and sway bar links.
The front end will feel brand new.
Rears are not as common. If you check the frame tabs where the bushings rest in and see shiny metal they need to be done.
Old 03-12-2018 | 10:28 AM
Okay, well I have only off roaded twice and the previous owner was literally a grandma, so I will refresh the front! I appreciate the input.
Old 03-12-2018 | 08:01 PM
Geo's Avatar
Geo
You didn’t mention how many miles are on it.
I did the lowers on the front along with tie rods at first. After changing the upper front arms later, the suspension clunks finally are gone. I would do upper and lowers at the same time. The uppers are cheap. I think I paid $65 each for OEM.
I had a heck of a time getting the lower ball joint and hubs separated and ended up pulling the top ball joints away from the hub and removed the lower arms still attached to the hub. Two whacks with a hammer and they were loose. If you have a lift, you may have an easier time.
Check the sway bushings while you are at it. See if you can move the sway bar side to side (slide through the bushing).
If you are paying for labor as well as parts, it will add up quickly, but should drive like new!
Old 03-12-2018 | 08:36 PM
135,000 miles! Does that change anything you said or is it still applicable? I am doing it all myself, so saving a huge hunk of change
Old 03-12-2018 | 09:38 PM
Geo's Avatar
Geo
I’ve got 139k, so sounds like it might be time..
agarabaghi
LR4
09-24-2014 10:26 AM
Drillbit
04-04-2014 03:10 PM
slickzero76
02-21-2014 06:44 PM
comleader
01-06-2014 07:56 PM
millejdq
12-06-2007 01:23 PM
