front hub noise
front hub noise
We have a growling noise at all speeds on left front, I am guessing at 75k miles the hubs going now?
If the road curves one direction it goes away can't remember left or right
Gonna pull the wheel today and look, is there a offered bearing to buy I see they are cheap to very expensive on amazon
My experience is to buy hubs with Timken bearings in them. I have gone the cheaper route before but ended up replacing them within a year. This was on my Excursion but the same reasoning would apply for the Landy.
Pulled the wheel I see nothing wrong with the bearing no leaking oil or excess movement with the tire on and wheel off ground
I do see my tires getting trashed on the outside and noticed the alignments out again , runs off to shoulder if you let go of wheel , alignment does not hold well on this truck. , so thinking the noise is the tire being chewed up
So this noise is slowly getting louder even last low speeds like 10 MPH sounds like I have a bad *** mudd tire on there , straight and turn left road curves left noise is there
Turn right or road curves right noise gone
On the bright side I replaced the brake sensor in back No more chime and lite that was 6 months of hell for a 10$ part and a few minutes labor lol
