Fuel Sending Failure
Old Sep 3, 2017 | 01:22 PM
gmad's Avatar
Default Fuel Sending Failure
Fuel level rapidly began dropping. Filled the tank. Still shows empty.
The scanner shows Fuel Sender 2 pegged at 1023 ohms.
I've heard the horror stories of dropping the tank, etc. any suggestions? Rig both wires up to #1 and just have a crappy gauge?
Old Sep 3, 2017 | 07:48 PM
abran's Avatar
I take it 2 is the forward most sender, if so... good luck.
i just replaced one with a good used tank as the level sender is almost impossible to change.
Old Sep 4, 2017 | 09:26 AM
gmad's Avatar
Yup. Forward, the more difficult one. (I was hopeful that #2 would be rear, but nope.) How was the process of replacing the tank? Do you mind sharing what you paid for a used one?
Old Sep 4, 2017 | 09:41 AM
abran's Avatar
It's a lot easier then you would think. There is a write up by another member, Tom, in the sticky section. I have a lift and a trans jack with fuel tank bracket, so it's a little easier that way.
We part out Rovers so I had the tank. We sell them with fuel pump and senders still installed for $200-$250.
We perted out an 05' recently that had a completely different looking tank with a "serviceable" front sending unit, meaning it has a threaded ring. After checking the tank, it had a 2012 production date. I imagine it's the new design found in the LR4, they got smart.
Old Sep 4, 2017 | 09:54 AM
gmad's Avatar
Installing a used tank has a risk though, right, that the senders could go out at any time too?
Old Sep 4, 2017 | 10:01 AM
abran's Avatar
No, used parts are bulletproof! Jk, of course.
A dealer tech told me that before they were replacing tanks they cut open and old tank and had a tech with the smallest arms practice changing the sender until he could do it blind folded.
njlandybabe
Defender
Jul 28, 2017 02:34 PM
savgre25
Feb 4, 2011 07:52 AM
kma32254
Dec 2, 2009 09:13 PM
Galaxie_406
Dec 16, 2008 11:57 AM
thehouseofkraus
Nov 25, 2007 07:27 PM
