Grinding Noise in Front End
Old Nov 11, 2019 | 02:49 PM
T.A.'s Avatar
Default Grinding Noise in Front End
I have a 2006 LR3 with a couple of things going on. It's not raising in the front so assume I have one or both air struts out, or possibly a bad block. In addition though, there is a grinding sound (and feel) when moving it either slightly forward or back; and it's worse if the wheels are turned. Any ideas on whether the issues are related and if not, what the grinding sound is?
Old Nov 11, 2019 | 03:12 PM
Grinding could be the diff or hub bearings. Or it could just be the tires rubbing if the suspension is fully compressed
Old Nov 11, 2019 | 06:24 PM
DakotaTravler's Avatar
Could also be one or both wheel bearings. Those are generally noisy when they go but not always. They may cause the truck to wonder a little when driving straight. To check just hold the wheels at 9 and 3 o'clock and see if they can be moved. And again at 12 and 6 o'clock. Basically see if there is play in the wheel. Also keep in mind if you front end is down hard they alignment will be off so aggressive off-road/mud tires will feel and sound very different.
moorebl
Aug 25, 2021 08:16 AM
lilherc
Apr 23, 2016 08:56 AM
oljohnboy
Jan 4, 2015 09:29 PM
nevillusa
Nov 19, 2014 03:59 PM
seattleLR3
Mar 17, 2012 09:52 AM
