Grinding Sound when Turning left
Old Jan 11, 2010 | 12:21 PM
Dlk0099's Avatar
5th Gear
Default Grinding Sound when Turning left
When I accelerate from being stopped if turning left while the car shifts from 1st gear to 2nd hear I am hearing a grinding sound. But I dont hear the noise when going right, or from any other gears or at higher speeds. This occurs only every now and then. I have a 05 LR3 with about 71K, all OEM parts no accidents. Does anyone know what this might be?
Old Jan 12, 2010 | 06:06 AM
Rovin4life's Avatar
wheel bearing or steering stops
Old May 21, 2011 | 10:47 PM
tdshort's Avatar
Did you ever find out what your problem was? I am having almost the exact same symptom.
Old May 22, 2011 | 08:05 AM
unseenone's Avatar
These issues are commonly associated with;
Left front wheel bearning shot You need to buy the hub bearings are not sold separately.
Lower Ball Joints.
Differential - front, rear or both, rear is more common. You may have also noticed, a dull roar building easily mistaken for tire noise that builds over the years. Parts are not available at LR or anywhere else. You can PM me for parts, and get an Indy shop to do the install.
Old Jun 7, 2019 | 11:19 AM
Tmassey's Avatar
Default Mine Just started
Hey guys. Mine just started doing this as wel. Only when I turn left.
I have had both hub assemblies changed up front. Still doing it. Any suggestions?
Old Jun 7, 2019 | 12:57 PM
TennRover's Avatar
I had a screech/sequel from the front left a while back only when turning the wheel. It ended up being a seized caliper.
Old Jun 7, 2019 | 01:14 PM
Tmassey's Avatar
This is more of a grinding than squeel
Old Jun 10, 2019 | 06:56 PM
patagucci's Avatar
im going to have to say it is the ABS being triggered by the anti roll over system. I would try to recreate it with the DCS OFF, and on to see if its the issue.
Old Jul 8, 2021 | 03:22 AM
sdjp's Avatar
not sure if anyone figured this out but I’m having it too on my 08’ LR3. It feels exactly like the grinding you get when the brakes kick in on the hill decent control. Additionally I’m getting an orange icon on the dash, a triangle with something in it. Now to figure out why this is happening. A few weeks ago my parking brake wouldn’t release and we had to remove the battery cable to reset things...
Old Jul 8, 2021 | 05:37 PM
DakotaTravler's Avatar
The triangle indicated traction control is operating. As mentioned this can be from worn suspension but typically a bad wheel bearing. Also the wrong sized (mismatched) tires can easily cause it or even a bad alignment.
Rover Chris
Jan 11, 2021 12:27 AM
EstorilM
Jan 12, 2017 07:43 PM
aaron22
Jul 4, 2015 09:15 PM
Aaron Sandland
Dec 7, 2014 07:48 PM
Wallyg
Feb 23, 2012 08:38 PM
