Guidance with AC Not blowing Cold
Old May 26, 2018 | 01:04 PM
mirepoixmatt's Avatar
Default Guidance with AC Not blowing Cold
She's blowing hot. Took her to my local independent guy (former rover mechanic) i've been using for years; he charged her and said she was blowing cold. By the time i grabbed her, she wasn't.
He said he put the UV die in it so if it leaked we could find it. I saw nothing with my UV light and still can't find it. I put another can in with UV die - nothing.
The system has no pressure.... 0 KPA's according to my cheap scan tool.
This is how i found it..
https://imgur.com/8ntqAtB
This is after a small can of 134a....
https://imgur.com/wRqXI1n
She blows slighly cooler after the 134a is in... she was blowing 100 before... blew 80 after (it's 91 today here in NY State).
Clearly i have a leak; i can't find it with the UV light....
what to do... what to do.....
Old May 28, 2018 | 10:18 AM
Uh oh. No responses. What does this mean?
For what it's worth, I threw 134a in the system and as I was doing so the compressor kicked on.... air went from 100 to 58. I thought i was in the clear (even through this same exercise was done 3 times). The difference is the car blew cold for an hour and maintained pressure. Assuming it was fixed, I turned her off... came back a few hours later.... and she's not blowing cold.
It would seem as if she'll maintain pressure until i turn the car off.
What could possibly cause that symptom? That seems so odd to me.
Old May 28, 2018 | 11:49 AM
abran's Avatar
You obviously have a leak.
The not obvious place to look would be the rear AC lines. I’m assuming it’s a 7 seater with rear HVAC. Check the evaporator at the rear drives side and follow the lines.
Old May 28, 2018 | 12:51 PM
DakotaTravler's Avatar
Yup, leak. Keep checking. There is a coupler above the rear diff area, if you have the rear AC. On mine, its leaking there a little as I can see oil covered dirt from that coupler down the line. Looks like a pain to get at so for now I put in some leak-stop.
Summer681
Dec 5, 2023 07:21 AM
nelsontod
May 19, 2012 09:25 AM
imike1007
Jul 21, 2010 09:29 PM
EATMAN
Dec 4, 2006 05:14 PM
