Hdc fault,lowered suspension fault,transmission fault
Old Nov 14, 2018 | 11:27 AM
dean19's Avatar
Default Hdc fault,lowered suspension fault,transmission fault
Hi,
Im wondering can someone help me out, I’ve a 07 Range Rover sport and Im getting they 3 faults up on dash I’ve read around this forum and a lot people said replace battery & brake switch which I did I’m still geting same faults up on dash
Old Nov 14, 2018 | 11:28 AM
abran's Avatar
If you have confirmed your alternator is good, I would check the T case ECU behind the battery for corrosion on the connectors
Old Nov 14, 2018 | 03:21 PM
DakotaTravler's Avatar
Are the brake lamps good?
Old Nov 14, 2018 | 03:25 PM
dean19's Avatar
lamps are good new break bulbs I can’t find problem I’ll check ecu tomorrow now
Old Nov 14, 2018 | 08:44 PM
abran's Avatar
Dakota might be on to sonething.
did this happen after you changed the bulbs?
Old Nov 16, 2018 | 11:20 PM
LKLK's Avatar
Check your brake light switch. It may be burnt out.
mroorda
Aug 23, 2020 06:51 AM
buick215
Mar 30, 2020 08:08 AM
Gansett LR3
Jan 9, 2019 11:58 AM
parksy
Jan 16, 2012 11:23 PM
parksy
Dec 1, 2011 04:41 AM
