HDC Fault in System?
Old Dec 10, 2007 | 11:16 PM
fanatic516's Avatar
Default HDC Fault in System?
When my wife starts the LR3 after it has been sitting for a while (cold) she says that the message center displays 'HDC Fault in System'. What does this mean?
thanks,
Jason
Old Dec 11, 2007 | 01:53 PM
Jantiz's Avatar
Default RE: HDC Fault in System?
HDC is the Hill Descent Control. Why it would be comming on is what I can not answer. Run it by the dealer!
Old Dec 16, 2007 | 10:51 PM
jimbiram's Avatar
Actually, I believe that is a general transmission or suspension fault. I find that it occurs in the mornings when the transmission is cold. If you shut off the engine, after starting, it probably will not come up. However, you should get it in so they can put it on the computer. My last visit found a defective thermostat, a software update for transmission, and wires on top of the engine that either a mouse or rat had chewed...
Old Dec 9, 2012 | 11:24 AM
dennywijaya's Avatar
I have 2007 Landrover freelander 2, buy a brand new 5 years ago, running almost 130k. But since 2 years ago, the car having many problems, from alternator, air conditioning and a years ago having HDC Faults message, sometimes the problem gone by itself. Yesterday I had same problem, having HDC Faults and the now car won't start...
I'm trying to find the solution through google and try one by one, but the car still wont start. Sadly, Only one dealer in Indonesia and I live in different city with the dealer.
Now I really hate with landrover, I regret buying a landrover, my personal experince, landrover is an expensive car with cheap parts. Don't buy landrover. unreliable. Please read any landrover forums before buy landrover.
Old Dec 11, 2012 | 08:11 PM
Northwind's Avatar
i had the same issue with my vehicle, the mechanic told me it's a "phantom" fault and not to worry about it. only happens when the vehicle is cold. i've pretty much forgotten about it.
06Range
May 8, 2013 09:01 PM
mrb06lr3hse
Aug 18, 2012 10:26 AM
