HDC and fluctuateing rpm
Old Oct 15, 2025 | 10:41 PM
Nahuebsch82's Avatar
Default HDC and fluctuateing rpm
Hey guys I'm new here...I have a couple issues im looking to fix in the future.
First, when I used HDC to test is was very crunchy sounding. The brakes are very smooth otherwise..no faults and no noise. Are there separate pads for the the HDC? Or is that normal? If they use all the same components i dont know why it would make such a chruncy/grindy sound.
Second, I get some fluctuateing RPM when under a slight load. Seems to mostly happen under a slight load and between 1000-2000 rpm. I replaced the TB already thinking it was the TPS going out but it didnt fix the issue. Thoughts on where to look next?
Thanks guys!
-Nick
Old Oct 20, 2025 | 04:47 PM
houm_wa's Avatar
HDC "crunching" is normal. It pulses the brakes at 40 times per second, so that's what you're hearing.
Old Oct 22, 2025 | 03:13 AM
loanrangie's Avatar
Get the codes read otherwise you are just guessing and buying unnecessary parts.
Seventh
Aug 11, 2024 11:40 AM
matt3502
Nov 1, 2010 10:19 AM
ayavner
Sep 8, 2010 01:09 AM
rgreenwell8962
Nov 3, 2007 03:44 PM
johnnybob06
Mar 16, 2007 03:20 PM
