HDC, Transmission, & Suspension faults, Special Programs off
Old Mar 14, 2024 | 07:26 PM
loanrangie's Avatar
Originally Posted by em63026
I have a 2009 LR2 which is demonstrating the same warnings, lights that you describe. The only common code we both have is the Invalid data from the ABS… I started experimenting problems initially after a huge snow storm, I had been driving in it and water, ice, snow, etc. was everywhere. After further examination, I realized the front right cv axle bracket mount bolt had broke off, which I believe would cause for some play in that wheel. I replaced the mount, the bolt, the hub, the control arm, tie rod, ball joint, strut, yet I am still getting the same results. I also had front right wheel speed sensor code and even replaced the wheel speed sensor with no change.
Any abnormal wear in any of the suspension or steering components can throw up those codes, you will need an alignment and steering angle sensor calibration if not done already.
mx468
Nov 16, 2022 05:00 PM
blpettis
Aug 11, 2019 04:17 AM
Mayemaye
Jan 13, 2018 07:22 PM
