Headliner Spot Repair Fix?
Old May 2, 2024 | 09:38 AM
DryFly Trout's Avatar
Question Headliner Spot Repair Fix?
Hello - curious if anyone has any experience with fixing headliners. Mine is in great shape most everywhere but has a few small areas where it's starting to come loose. Is it possible to secure those spots somehow so it doesn't "spread" ? Thanks
Old May 2, 2024 | 05:03 PM
DakotaTravler's Avatar
Once it starts to fail is will continue. The only temp fix is using a steamer which can penetrate the fabric enough to get the glue a little active again. But it probably wont last super long. A proper full re-cover is best. I was quoted $500 for mine to get done, but I plan to do it myself. Already did the a-pillars anyway.
Old May 3, 2024 | 07:38 AM
Thanks Dakota - that was what I was concerned about. $500 isn't as bad as I thought it might be and looking at doing it myself - I think I'd be in over my head - ( no pun intended!)
Old May 3, 2024 | 08:50 AM
Rufflyer's Avatar
Not sure it would work on the foam backing of the LR3, but on a D2 we had for adventure travels (read that as camping and beating it up in the mud) we just used multi color textured trunk spray paint on the cardboard backing and put it back in.
Again I would not do that to my wifes daily driver, but mine? maybe, maybe not.
My best advice is pull the whole thing and re-glue your self, or pull it and take to an automotive shop and have them re-glue/ refinish and reinstall it yourself.
Hope this helps
Jeff
whiskeynipple0088
Feb 24, 2020 09:57 AM
Rover144
Apr 5, 2015 07:02 AM
Dodger
Dec 30, 2010 12:29 PM
Aj6543
Sep 19, 2009 03:44 PM
DiscoGirl
Jul 28, 2005 01:49 PM
