Help - 2005 LR3 - Warning Lights, HDC, Stuck In Low...and more
Old Feb 15, 2018 | 10:45 PM
Bhalbach's Avatar
Default Help - 2005 LR3 - Warning Lights, HDC, Stuck In Low...and more
Can anyone help please., please
i have multiple codes, stuck in low range, suspension, HDC.
i have tested battery, changed brake switch, disconnected the entire tail light assembly to take the brake bulbs out of possibilities. Checked passenger side wiring and found broken wire (think I hooked to proper connection), checked the TCM behind battery for corrosion and cleaned the pins with electrical spray and put dielectic grease. Cleared the codes.
where do I go next? Driver side footwell wiring? Centre console wiring for possible water/coffee spilt?
im getting discouraged...always wanted a Landrover. Bought this one and can’t find the issues.
Old Feb 15, 2018 | 11:29 PM
abran's Avatar
Transfer case control module behind the battery. Check the connectors, probably corroded.
once confirmed, I have a replacement if you need it.
Old Feb 16, 2018 | 12:29 AM
Bhalbach's Avatar
i checked the module behind battery, it had some corrosion which I cleaned up with electrical cleaner and sand paper then dielectric grease...still no joy.
if corrosion existed on the module pins, will it work after they are cleaned? I have read yes and no.
Old Feb 16, 2018 | 04:03 AM
loanrangie's Avatar
Brake switch, very common cause of those errors on the dash.
Old Feb 16, 2018 | 07:49 AM
abran's Avatar
when you did the brake switch did you install with the pedal in its natural position?
ive had 4 vehicles with corroded TCCM and never had one work after cleaning. I also had a bad negative/ground cable at the battery cause issues. My money is on TCCM module, but you might try another brake switch and ground cable first.
Old Feb 16, 2018 | 01:56 PM
houm_wa's Avatar
Hi Abran, not to jack the thread but what's the shop time for replacing the negative cable?
Old Feb 16, 2018 | 03:28 PM
Bhalbach's Avatar
So this is what I have done today.
-cleared all codes.
-disconnected battery & charged again 12.6v tested
-cut out a somewhat corroded connection on passenger side in the wiring harness
-took apart centre console and cleaned all connections with electrical contact cleaner...no signs of corrosion.
-checked and cleaned connections in passenger side wheel well, including abs sensor.
-reconnected battery
-started lr3...no change.
-still stuck in low.
-dash says transmission fault traction reduced when put in park (after lr3 has been moved forward or backwards) and traction reduced.
-hi /low still not working, just flashing hi and lo on switch and green light flashing on dash no ding when pushing switch.
-hdc yellow switch does nothing, no ding no lights, dash says hdc fault system unavailable when key turned on.
-dsc switch does nothing, no dings light is solid amber on dash.
-suspension switch flashes both arrows on switch when pushed and dings...then the switch show “up” solid amber...when start moving suspension light comes on dash...goes away when lr3 turned off then back on.
-the mode switch when turned says dings and says system fault special program unavailable and special programs off.
-parking brake will not disengage by itself when put in gear and push accelerator.
any thoughts or advice?
Old Feb 16, 2018 | 04:53 PM
Bhalbach's Avatar
-cleared all codes.
when I do a hard reset the compressor will turn off when I start lr3 and run for maybe a minute then done...won’t start again.
Old Feb 16, 2018 | 05:08 PM
Bhalbach's Avatar
Cruise won’t turn on, I assume it is related to being stuck in low range.
abran's Avatar
Change out TCCM
