Help with choosing tires
Old May 13, 2013 | 08:27 PM
Kinz384's Avatar
Default Help with choosing tires
Ok. I got a flat. And just found out I gotta replace all 4 tires since its awd
It has the goodyears on it. Those are too expensive.
I drive just city / hwy. 2 kids. Single. Money is tight.
no one in my area has this size. And limited on brands without ordering & I can't be without my ride for 3-5 days waiting on shipment to get in.
So as of now. My 2 choices. That they have in stock are
Cooper h/t plus 265/60/18
Or
Firestone destination le2. 265/60/18
I'm lookn at all 4. Installed. $648. & $756
Anybody know how good these tires are ? Which is better way to go ?
& by gng little bit bigger. How's it affect my mpg ? Or even the computer readings ?
Thanks
Old May 13, 2013 | 10:36 PM
stmcknig's Avatar
If you can find a matching brand to your other three and they are still good, you may want to get the one tire shaved...see this
Tire Tech Information - Matching Tires on Four-Wheel Drive and All-Wheel Drive Vehicles
May not be ideal but if money is tight and the other tires are pretty good, this should work out cheaper.
Old May 13, 2013 | 11:19 PM
Kinz384's Avatar
Very interesting.
My other 3 aren't to far from needing replaced.
& matching gy wranglers. Still have to be ordered. No one has em. & was told its $512 for one tire.
Old May 14, 2013 | 06:44 AM
stmcknig's Avatar
OK, I think the wranglers were the original fit tire so they were expensive and didn't wear very well. Guess you're right, probably time to replace with something better.
Old May 22, 2013 | 08:51 AM
paulstring's Avatar
I have almost 50,000 miles on a set of Open Country tires from Les Schwab. I would, very much, recommend these tires. Drives very well on and off the tarmac. Not a hugely aggressive off-road tire, but the best of both worlds.
Old May 22, 2013 | 09:37 AM
re: 2 kids. Single. Money is tight
LR3 maintenance schedule - so you can plan. Differentials need fluid replaced much more frequently (not at 150,000) - the $30 fluid fills, lubes, and cools a $2200 part. Early maintenance is important to keep Rover repair costs to a minimum.
File Type: pdf
Old May 31, 2013 | 07:36 AM
cfd01's Avatar
When I was on a tight budget I would scour Craigslist for used tires or just pop in the few local used tire shops (plenty here in Chicago). Usually got a set with 90% tread and no damage mounted and balanced for under 400 then I'd drive over to Firestone to get them properly balanced because used tire shops usually use a cheap Snap-On balancer. I don't know how easy it would be to find rubber for the 3. As we all know the pickings are slim in regards to tires.
Lupin 3rd
Nov 5, 2012 05:42 PM
Hyakku
Apr 7, 2012 12:05 AM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
stonnie
Aug 19, 2008 04:01 PM
