Help! Out of town and weird noise!
Old Jan 28, 2015 | 11:34 AM
houm_wa's Avatar
So for $2k you get: bearing, hub, tie rods and an alignment? Or does that include the LCAs too? If it includes LCAs then that's a good deal!
Those guys at Columbia are good. I used to go wheelin' with one of their founders (he's moved on now)
Old Jan 28, 2015 | 03:30 PM
Oasisplayer311's Avatar
That's for everything, lower control arms, brake pads and new rotors included! And their replacing the whole wheel hub assembly, not just the bearings. They also got it all done in a half day! Great guys, even took me through all my old parts and showed me the damage. Can't wait to drive it! They just drove it over to get the alignment!
Old Jan 28, 2015 | 03:55 PM
houm_wa's Avatar
Sounds like they took good care of you!
Old Jan 29, 2015 | 06:38 AM
thorgal's Avatar
Now, Remember that car, with newly LCA done should be driven for at least 15 miles or left in facility overnight , in order for the new bushings to settle, before the alignment. Otherwise , you risk a improper camber set up as the bushings will set in slightly as you begin to drive and your alignment will be off balance, so to speak.
I would not worry much ,if I had old , worn tires, but if those where new, i would make sure they followed this procedure.
alpineclimber
Jan 31, 2010 04:56 PM
grussell
Sep 2, 2009 11:54 PM
ALEXAN
ROAMING WITH FRIENDS
Aug 28, 2009 09:47 PM
Disbet
May 28, 2008 08:15 AM
