Help please w reset info
Old Dec 15, 2019 | 02:02 AM
info@fosterslbi.com's Avatar
7th Gear
Default 2008 lr3
So now I have electric and no cranking no clikinh
Old Dec 15, 2019 | 02:04 AM
Globetrotter448's Avatar
No power - As indicated, check the large fuse in front of the battery. Also check the cable through to the starter motor as it is known to rub on the front diff and short out.
Old Dec 15, 2019 | 10:18 AM
DakotaTravler's Avatar
Thats scary. Is that for all Disco 3? I never heard of that. When I did my starter on the 4.4 I dont see how such a thing would be possible.
Old Dec 15, 2019 | 11:02 AM
Never heard of that either
Old Dec 15, 2019 | 11:15 AM
houm_wa's Avatar
Default X3
Nm...
Old Dec 15, 2019 | 03:49 PM
Threads on UK forum. Seems like the cable becomes loose or clip breaks. May only be applicable to those doing a lot of off-road stuff but has occurred.
Old Dec 15, 2019 | 04:02 PM
Might be a diesel issue
Old Dec 15, 2019 | 07:51 PM
loanrangie's Avatar
Possibly, starter is on the RH ( driver ) side so might drop down and rest on the diff nose.
Old Dec 16, 2019 | 12:06 PM
7th Gear
Default Continued...
How do I check the large fuse in front of fuse box with the positive cable going through it. What tool is needed and is the fuse accessible or special order type
Old Dec 16, 2019 | 12:11 PM
Just pull it and look. I think it just snaps apart with two bolts that secure the fuse to the positive lead on each end. Its just a high amp strip fuse. A decent auto parts place usually has them. I think its rated for 400 amp.
CameraDan
Sep 12, 2019 11:52 AM
aemnky606
Nov 12, 2016 11:38 AM
Germanwerks
Aug 27, 2015 10:16 PM
roverwoody
Jan 28, 2014 09:46 AM
Danny Lee 97 Disco
Jul 15, 2011 09:15 AM
